May 28, 2012, 01:11:03 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Another screen size question
Pages: 1   Go Down
Print
Author Topic: Another screen size question  (Read 2216 times)
Greolt
Global Moderator
Offline Offline
View Profile
« on: July 10, 2007, 08:13:00 AM »
I am now the proud owner of a 12" touch screen. 800 x 600.
Making my "Bright Buttons" screen layout to suit the small size.
Now my issue is....... I want to make my screens the right size so that they do not need to be resized by Mach.
There by not mucking up the text on Gcode lists etc.
It just all round comes up better at native size.
However I find I must set the "Auto Screen Resize" otherwise the wizard screens are not usable on the 800 x 600 screen.
Does anyone know a work around for this?  Getting the wizard screens to show on 800 x 600 without "Auto Screen Resize"
Greg
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #1 on: July 11, 2007, 10:45:28 PM »
Bump   Grin
zealous
Active Member
Offline Offline
View Profile WWW
« Reply #2 on: July 12, 2007, 04:55:33 AM »
The only way I can think of is opening the wizard screen set and modifying them in Screen4,
Set your "Desired Screen Size" to 800X600 and drag and resize things, maybe with the new Jetcam screen set he will add something to aid with this.
Regards, Jason Blake
www.Fusioncnc.com
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #3 on: July 12, 2007, 05:55:42 AM »
G'day Zealous
I seem to have got around it by building my main screens to just the right size so that Mach does
not distort them at all when doing "Auto Screen Resize"
Then it will show the wizards and the 1024 which I use as my "sset" at the adjusted size.
The odd bit of text blur etc does not matter on those. And my main set still looks sharp,
By the way has Jetcam dropped off the shelf?  I hope not.
I would love to be able to do my screen in Flash but it's a bit beyond me.  Grin
I have seen what you have done with being able to easily alter button colours etc on the 1024 set
but that is not what I need.  Mine is a complete new screen layout.
Thanks,  Greg
« Last Edit: July 12, 2007, 06:07:05 AM by Greolt » Logged
Pages: 1   Go Up
Print
Jump to:
