Hello Guest it is June 09, 2026, 05:38:16 AM
Author Topic: ekstromcarlson spindles  (Read 7954 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« on: July 06, 2007, 03:38:43 AM »
Hi - anyone have any experience of these? http://www.ekstromcarlson.com/spindle%20motors.htm
for example Motorpack 3 under http://www.ekstromcarlson.com/router_packages.htm
I'd also be interested if anyone in the UK has imported them.
many thanks
Stirling
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: ekstromcarlson spindles
« Reply #1 on: July 06, 2007, 07:52:32 AM »
I Have not used those. I use http://www.hsd.it/home.asp I have been very pleased with the performance. They are out of Italy and should be easy to find locally. I am sure you can find a VFD for them or they probably could recommend one. I upgraded from a heavy duty router and never looked back.  There is also http://www.pdscolombo.com/products.htm
Chad
Offline stirling
  •  2,188 2,188
  • UK
« Reply #2 on: July 06, 2007, 01:56:22 PM »
Thanks Chad - I'll take a look - probably won't be able to afford them (stuff costs a fortune over here) but it's worth a try.
cheers
Stirling
