Hello
Guest
it is
June 12, 2026, 08:54:07 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Installing new version of mach 3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Installing new version of mach 3 (Read 8865 times)
bogger44
9
on:
June 27, 2007, 11:26:19 PM »
I'm trying to install a newer version of mach 3. I have v2.05 running and everything works.
When I instal v2.65 it won't work. When I load g code it dose'nt load it all and gives an error: Radias at beggining of arc differs from radias at end of arc on line 20. It also does this if I try to install v2.30
I'm using PLASMA and this looks like it's the leadin arc that the error is on. BUT the v2.05 has no prob. same g code loaded from the same place.
I reinstall v2.05 and everything works again. Thanks for any help.
Chaoticone
5,624
Precision Chaos
Re: Installing new version of mach 3
Reply #1 on:
June 28, 2007, 07:45:15 AM »
Hey Bogger,
Try this, go to config, general config. and change the the IJ mode.
If you could see the things I have in my head, you would be laughing too.
bogger44
9
Reply #2 on:
July 03, 2007, 11:52:54 PM »
I tried changing the IJ mode and no go. In the pulse freq. it said simulate and there is no "charge pump". I will reexamine but I think all the settings are the same. Tried 2v80 and same thing but when I install 2v05 it says 2v... already installed do you want upgrade to 2v05 and I say yes and the 2v05 works fine.
Print
Pages:
1
Go Up
« previous
next »
