May 28, 2012, 01:05:42 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Mach3 and G-Rex
| | |-+  Soft Limits
Pages: « 1 2   Go Down
Print
Author Topic: Soft Limits  (Read 3446 times)
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #10 on: June 19, 2007, 07:03:28 PM »
I don't know if that was the right xml. Nothing is set in ports and pins. I don't get the red blinking softlimits but I think you may be using a xml. other than the one you posted.
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #11 on: June 19, 2007, 07:05:39 PM »
Also, don't save it as a text file. Just copy your xml and rename, then post. Only rename the part before the extension .xml
jomarl
Active Member
Offline Offline
View Profile
« Reply #12 on: June 19, 2007, 09:02:53 PM »
Here's the other one....Sorry but I had to copy the file to my jump drive to bring it over from the computer that is not on line. Can't attach it directly to this post. Joe
jomarl
Active Member
Offline Offline
View Profile
« Reply #13 on: June 20, 2007, 01:30:45 PM »
Brett, here is .xml file as copied...Joe
* JLsxmlfile.xml (47.23 KB - downloaded 127 times.)
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #14 on: June 20, 2007, 06:34:47 PM »
Joe, I sent you a personal message.
jomarl
Active Member
Offline Offline
View Profile
« Reply #15 on: June 21, 2007, 12:54:41 PM »
Thanks Brett. Here is 1000-PLASMA.xml. Joe
* 1000-PLASMA.xml (46.98 KB - downloaded 79 times.)
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #16 on: June 21, 2007, 01:22:00 PM »
Hey Joe,
    I'm still not getting the red around the softlimits button. What screen set do you use with this profile? Can you post it as well? I have sent you a personal message.
Pages: « 1 2   Go Up
Print
Jump to:
