Hello Guest it is June 09, 2026, 08:09:59 PM
Author Topic: Soft Limits  (Read 29333 times)
Re: Soft Limits
« Reply #10 on: June 19, 2007, 07:03:28 PM »
I don't know if that was the right xml. Nothing is set in ports and pins. I don't get the red blinking softlimits but I think you may be using a xml. other than the one you posted.
Re: Soft Limits
« Reply #11 on: June 19, 2007, 07:05:39 PM »
Also, don't save it as a text file. Just copy your xml and rename, then post. Only rename the part before the extension .xml
jomarl
Re: Soft Limits
« Reply #12 on: June 19, 2007, 09:02:53 PM »
Here's the other one....Sorry but I had to copy the file to my jump drive to bring it over from the computer that is not on line. Can't attach it directly to this post. Joe
jomarl
Re: Soft Limits
« Reply #13 on: June 20, 2007, 01:30:45 PM »
Brett, here is .xml file as copied...Joe
Re: Soft Limits
« Reply #14 on: June 20, 2007, 06:34:47 PM »
Joe, I sent you a personal message.
jomarl
Re: Soft Limits
« Reply #15 on: June 21, 2007, 12:54:41 PM »
Thanks Brett. Here is 1000-PLASMA.xml. Joe
Re: Soft Limits
« Reply #16 on: June 21, 2007, 01:22:00 PM »
Hey Joe,
    I'm still not getting the red around the softlimits button. What screen set do you use with this profile? Can you post it as well? I have sent you a personal message.
