Hello Guest it is June 08, 2026, 11:45:33 PM
Author Topic: ******Guess and win a G100 Grex******  (Read 830897 times)
0 Members and 10 Guests are viewing this topic.
« on: May 14, 2007, 08:46:20 PM »
 :D Win a free Grex :D!!!!!!!!!!!!!!!!!!! ;D Mach licenses ;D & a :o G100 plugin :o[/u][/color][/size]
You can win this package worth more than ;D $600.00 ;D by guessing the number of chips in the picture below. The winner will be announced May 29th unless someone guesses it spot on before that time. If no one gets it spot on by then, I will award it to who ever is closest. I will be giving hints from time to time so keep an eye on it. The first hint is, the number is between 3,000,000 and 2,000,000. Only one entry per member. It can however be edited at any time. In other words, you can go to your original post and edit the number you wish to submit. That is, until we lock it on the 26th.
If anyone doesn't know what this competition is for here are links to pages that will help you understand.
http://www.artsoftcontrols.com/
http://www.geckodrive.com/product.cfm?pid=19
Special thanks to Benny, Mariss of Gecko Drives, Stephen Hardy and Artsoft for putting this into motion.
« Last Edit: December 03, 2016, 04:17:11 AM by Tweakie.CNC »
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: Guess and win a G100 Grex
« Reply #1 on: May 14, 2007, 09:05:28 PM »
Hi:
 Can you post a higher resolution picture, I keep losing count due to pixelation of the image. I keep losing count at about
673.. I know there must be more than that..
LOL. :-)
Art
« Reply #2 on: May 14, 2007, 09:15:09 PM »
Well using the Beverly Hillbilly math, whis naught tymes naught is naught I guess 2,662,798 ;D
If I need to re cyfer it, let me know!
Mike
edited to add the # of completion
« Last Edit: May 22, 2007, 08:52:27 AM by turmite »
« Reply #3 on: May 14, 2007, 09:31:04 PM »
1..2...3.....
1...2....3.....
Alright, I'll just say......2,304,000!
« Reply #4 on: May 14, 2007, 09:35:43 PM »
Hi, the correct number is 2,746,200  i just finnished counting! cul brian f.
« Reply #5 on: May 14, 2007, 09:48:16 PM »
Hmmmmm.......
Based on the size of the cutter, angle of the light, material being cut, noise coefficient of the influx jitter, and local weather (here not there), I'll say: 2,134,618.
Doug
« Reply #6 on: May 14, 2007, 09:53:46 PM »
Hello !!!
My bet is 2,915,767
See ya
jkeyser14
« Reply #7 on: May 14, 2007, 09:56:42 PM »
2,601,572
« Reply #8 on: May 14, 2007, 10:17:07 PM »
Well lets see. on: May 14, 2007, 06:46:20 pm the moon was about to rise giving max magnetic pull at 11:05 pm. The Earth's diameter is about 12,750 km, and the distance from the Earth to the Moon is about 385,000 km.. So its obvious 2,883,888 chips.
Later
Bob
« Reply #9 on: May 14, 2007, 10:32:57 PM »
2,608,713 did not count the ones on the floor....gabriel
« Last Edit: May 23, 2007, 10:40:57 PM by gabrielr »
