Home
Downloads
Mach and LazyCam
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
German Forum
Italian Forum
Portugese Forum
Resources
Links
User Reviews
User Videos
Contact Us
CNCZone
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
November 21, 2008, 01:19:33 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Newfangled Solutions Wizards
New Wizard
Pages:
1
Go Down
« previous
next »
Author
Topic: New Wizard (Read 1614 times)
vmax549
Guest
New Wizard
on:
May 10, 2007, 08:02:24 PM »
Hi ROn, If you are interested we sure could use a wizard to do Coordinate Base Rotation using the probe to calculate the angle change. Brian started one but it did not use the probe. I have a crude version that I use but it is ugly(;-)
Also we could use a wizard to probe a 2d shape and create the Gcode file.... It would be a cross between the teach wizard and a probing solution for 2d shapes. I have the process worked out but the wizard programming is beyond me. (;-)
I have many more but those are ones I use all the time.
poppabear
S S SYSTEMS, LLC
Global Moderator
Online
Briceville, TN, USA
Re: New Wizard
Reply #1 on:
May 10, 2007, 08:40:26 PM »
If you look on the "conversational Wizard" Screen that I put up, on one of the pages I put a Base rotation calculation that take into affect quadrants and will post out the correct G68 code for you.
Just open up the Button and look at the script, you will see the code you need for that.
Scott
All things Mach3, Screens, Wizards, Plugins, Brians, complete control solutions for complex machines, Macros, ATC's, any kind of CNC machine build, retrofit or repair.
Ron Ginger
Active Member
Offline
Re: New Wizard
Reply #2 on:
May 14, 2007, 05:58:24 PM »
Yes, Brian and I have talked about a rotation wizard. It should be fairly simple. I have done a set of buttons that I use to pickup any edge of my vise, or to set Z depth. I intend to make them into a wizard, but just havent got the 'round tuit' yet.
vmax549
Guest
Re: New Wizard
Reply #3 on:
June 10, 2007, 10:32:01 PM »
Scott, where would I find the wizard you speak of? (;-) TP
TDAY
Active Member
Offline
Re: New Wizard
Reply #4 on:
June 24, 2008, 10:16:25 AM »
Ron,got idea for new "simple" wizard.A Line to Line mill wizard,that would have the option to put a Radius or angle at the end of line. That is similar to the Multi-Hole wizard ,except there would also be a Z axis ,Angle,and Radius DRO to enter.Also the M1 function i asked about in the other post.
"I try to put forth the effort,before asking a dum question"
poppabear
S S SYSTEMS, LLC
Global Moderator
Online
Briceville, TN, USA
Re: New Wizard
Reply #5 on:
June 25, 2008, 07:51:01 PM »
Hey Ron, adn vmax549,
Here is how I did G68 rotation calcs, from the Convo wizard..... in the VB and wizards thread, page 4 in screen designer.
you could pick, the first Rotation point, or get fancey and probe it what ever, or just transfer in the current X1 Y1 coor. for point 1,
which is the corner of the Vice or whatever.
Then you could Jog, or probe, or transfer in the second point X2, Y2.
note: x1 and x2 cannot be equal......
note: y1 and y2 cannot be equal......
Use 5 UserDROs,
The following was in a G68 calc angle button:
'***********start calc, button script*********************************
Sub Main()
'G68 angle calc
SetUserLed(1039,1) 'this led was flipped by a button, to signify using this function. to append it to the teach file in the Addoffset button at bottom.
x1=GetUserDRO(1081) 'put whatever userDROs you want here.
y1=GetUserDRO(1082)
x2=GetUserDRO(1095)
y2=GetUserDRO(1096)
D=1
pi = 4 * Atn(1)
If x2-x1=0 Then
Message("X2 cannot = X1!!")
Exit Sub
End If
If y2-y1=0 Then
Message("y2 cannot = y1!!")
Exit Sub
End If
If y2=0 Then
Message("y2 cannot = 0!!")
Exit Sub
End If
If x2=0 Then
Message("X2 cannot = 0!!")
Exit Sub
End If
If y2>y1 And x2>x1 Then
D=D*1
End If
If y2>y1 And x2<x1 Then
D=D*-1
End If
If y2<y1 And x2<x1 Then
D=D*1
End If
If y2<y1 And x2>x1 Then
D=D*-1
End If
a=y2-y1
b=x2-x1
ang=(180/pi) * Atn(a/b)
If D>0Then
SetUserDRO(1094,ang)
End If
If D<0Then
End If
End Sub
Main
'********End Calc button script***********
The following was in a "Add Offsets button" that if the Use coordinate rotation button LED was on, (for to use it)
Then, this code was "Appended" to the teach file. I just took out the G68 stuff and did not put in all the other
stuff from that page............again open it up in screen designer if you want to see more crap..........
'*******Add Offsets button (with out Append and teach file stuff)**********
A=GetUserDRO(1081)
B=GetUserDRO(1082)
R=GetUserDRO(1094)
If GetUserLED(1039) then
Code "G68 A" & A & " B" & B & " R" & R
End If
'**********End Add Offsets button**********************
Scott
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*e*i*n*g
=> Mach Screens
=> Feature Requests
=> Non English Forums
=> FAQs
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> Lazy Cam (Beta)
=> LazyTurn
=> dspMC/IP motion controller
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Promote and discuss your product .
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
=> One on one phone support.
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
Loading...
