Hello Guest it is June 09, 2026, 04:25:47 AM
Author Topic: Homing in Mach 3  (Read 35142 times)
catheic
Re: Homing in Mach 3 (Help please)
« Reply #10 on: April 05, 2006, 03:05:08 AM »
i can't home my machine too. and my axes are reversed. my z for example, it should start 0 from the top going negative downwards. right now, it's reversed. even if i click "reverse" it doesn't work...and more thing for instance i already reached the lowest my max z can travel, how do i bring it back up?
here are the screen shots of my configs
« Reply #11 on: April 05, 2006, 07:09:57 AM »
Dude,
I am no expert but it sounds like you are on the wrong settings page.  Look under the config menu for the "Homing/limits" section.  Try the Home Negative and reversed check box there.  It probably would be good to also watch the video about homing/limits that is on the Artsoft website IMHO.
Good Luck!
Sid
catheic
« Reply #12 on: April 05, 2006, 09:31:49 AM »
hi Sid,
thank you for your reply.
i tried that and no luck. i did clicked reversed and home negative. i will try again tomorrow morning. thanks again bud!
« Reply #13 on: April 05, 2006, 09:31:59 AM »
It sound like the Dir pin is not changing... If you jog the Z can you move it up and down?
www.newfangledsolutions.com
www.machsupport.com
catheic
« Reply #14 on: April 06, 2006, 01:36:20 AM »
i am jogging Z using the reference z button. now when i do that it doesnt move at all. it says one or more home switches  are active . please fix then home.
wahhh i am getting frustrated please help. i am using MAXPATH 42.. its a CL.
thanks so much for your help!
Cathei
« Reply #15 on: April 06, 2006, 08:05:35 AM »
Is that computer hooked to the internet? I may be able to do some support with MSN messanger
www.machsupport.com
