Hello Guest it is June 09, 2026, 08:45:26 AM
Author Topic: How in VB to ensure the script changes to Machine coords or work coords??  (Read 8592 times)
Offline Tarak
  •  229 229
I think I've looked everywhere (obviously not)
I'm trying to press a button to zero my grinding wheel, then it changes the offset to suit, as per below:
1 Set grinding wheel at zero (approx -37.3 in machine coords) (I've successfully done this)
2 press button ZERO WHEEL (I've successfully done this)
3 changes to machine coords (I can't work out how to do this, at the moment I'm doing this manually)
4 copy's the value in machine coords to a second DRO, but a positve value. (I've got it copying, just not in a positive value)
5 change back to work coords (I can't work out how to do this, at the moment I'm doing this manually)
6 Moves out to home switch (I've successfully done this)
7 Copies the value from the second DRO into the work coords (I've successfully done this)
8 Voilla!!
I'm trying to take a negative value from one DRO and put the same value into another DRO, but a positive value.
The way I do this on a cnc is as follows, I'm just can't get the syntax correct for VB.
#1=-10.00
X[#1-[#1*2]]
This is as far as I've gotten
'change to machine coords here
y=GetDRO(1)
While IsMoving()
Wend
SetOEMDRO(1202,y)
'change to work coords here
DoButton( 23 )
While IsMoving()
Wend
y=GetUserDRO(1202)
CODE "G92Y" &y
« Last Edit: April 28, 2007, 10:52:41 PM by Darc »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
To convert a negative number to positive in VB use ABS(n)
e.g. A=Abs(-123.456)
A=123.456
you can also do this
CODE "G92 Y" & ABS(GetDRO(84)) ' read machine Y dro
Graham.
« Last Edit: April 29, 2007, 01:36:51 AM by Graham Waterworth »
Offline Tarak
  •  229 229
Thanks, Graham.
I ended up using your code like this:
CODE "G92Y" &Abs(y)
I still can't work out how to get it to change from Work to Machine coords and visa versa.
The standard button that switches inbetween work and machine coords is OEM code 256, I just don't know how to work out what this code does?
  •  2,785 2,785
Have you tried DoButton(256)
Graham.
Offline Tarak
  •  229 229
Thanks again Graham, it worked using DoOEMButton(256).
