Hello Guest it is June 09, 2026, 01:31:02 PM
Author Topic: G100 Upgrade on B-I-G CNC Router  (Read 13731 times)
Offline Haik
  •  71 71
  • MachUser
« on: April 26, 2007, 02:21:34 AM »
Hello All,  Here's my retrofitted and upgraded Thermwood Catesian 5 [96"x48"x7"] CNC Router:
All the OEM stuff is long gone and now it's setup with Gecko G100, Gecko Drives (X, Y1, Y2, Z, A).  Also, there's spindle ON/OFF and accessory relays.  My only remaining task is to upgrade the spindle to HSD (or maybe Colombo) water-cooled 24k RPM with ATC.
Not directly visible in pics is the 2.5" tall extruded aluminum heat-sinks that the Gecko Drives are mounted to. Dual large 115vac fans force air through the sinks keeping the drives cool.  This is needed since the stepper motors are very large NEMA 42 80v w/2600 oz/in holding torque.
The machine is very fast and runs comfortably @ 250 ipm for when jobs require that.  The G100 does a great job at keeping things smooth.  This setup really gets me some great quality finishes.
-Haik
« Last Edit: April 26, 2007, 02:40:05 AM by hbaba »
Re: G100 Upgrade on B-I-G CNC Router
« Reply #1 on: April 28, 2007, 09:13:33 PM »
Nice to see there is an other guy running full size machine :)
Keep up the great work
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 02, 2007, 10:01:19 AM »
Haik,
Nice to see my old machine still going and improving. Looks good with that G100 in there. How did you hook up the relay board to it?
I see you added a Vampire to it for the A. Have you found a A yet. I still have the motor and rotary table I used for my A when I had it.
Probably a good thing you upgraded the fans. They were on the week side.
Nice you see it again. Glad its working out well for you.
Other than not using the Parallel port do you see any improvement to the G100 over the Breakout Board?
Donny
Offline Haik
  •  71 71
  • MachUser
« Reply #3 on: May 02, 2007, 03:30:42 PM »
The Campbell-Designs relay board has 12vdc relays on it, which is just what the G100 "Digital Outputs" will provide (up to 100ma) each.
The Gecko documentation poorly describes the usage of the Digital Outputs, so here's the deal:
Connect one leg of 12vdc relay coil to a G100 Digital Output (1-16), connect the other leg to the power supply positive (+).
Functional description of G100 Digital Output (port):
The Digital Output is @ HI (+12vdc) when off (no output/indicator not lit).  When the Digital Output is on/enabled it goes LOW (becomes 0vdc/Ground) and its indicator light is lit.
The next step is to configure Mach3:
Configure | Ports and Pins | Output Signals...
 Outputs are listed as "Output #1(-16)"; assign the Output of choice "Port #" = 1 (very important!!); The "Pin Number" is not used, so its value doesn't matter; "Active Low" is set to X
If Digital Ouputs are used for the Spindle and/or Flood/Mist Control then also do the following:
Configure | Ports and Pins | Spindle Setup
 Assign appropriate "Output #" for "Relay Control"-"Clockwise(M3)" and CCW(M4) and also for "Flood Mist Control"-"Mist M7" and "Flood M8" if used.
... and that's it!
The G100 is much smoother, the steppers are quieter and more responsive and can go faster without stalling.  There's some exclusive G100 path and velocity settings that affect the results of G-Code and I'm still experimenting with those.  Previously, (in Windows XP) some apps when launched or closed and while Mach3 was open would ping the LPT port of my computer causing the machine to jump and lose position even though G-Code was not running... that's gone now.  Overall, it's just a cleaner and more reliable approach and has greater possibilities for extending the machines capability.  Certainly worth the $400 and the conversion labor.
One Mach3 caveat is that the Tool Path info is virtualized so Mach3's tool pathing green dots are an estimate of reality, so what they show you is approximate.  I spoke with Art about this and did my own tests and the reality is that the G-Code is accurate and the programmed part is true.
-Haik
« Last Edit: May 02, 2007, 09:20:17 PM by hbaba »
