Hello
Guest
it is
June 12, 2026, 12:55:10 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Trouble Getting Started
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Trouble Getting Started (Read 20159 times)
DirtyBird
5
Re: Trouble Getting Started
Reply #10 on:
April 13, 2007, 02:26:03 PM »
The motor will not jog. The X axis on screen position does change, but the motor is not responding.
Reply #11 on:
April 13, 2007, 02:30:06 PM »
I also notice you have Enable 1 set for port 1 and Pin 0, do you need the enable for your drives if so then you will have to set the correct pin.
Also did you try changing the Dir/step active state like chip suggested earlier?
Chip
2,055
Gainesville Florida USA
Reply #12 on:
April 14, 2007, 10:17:54 PM »
Hi, DirtyBird
Give this XML a try, Turned on Jog On/Off, (Hood), Changed Dir/step LowActive state to "Checked".
Hope this gets It, Chip
DirtyBird
5
Reply #13 on:
April 17, 2007, 06:07:14 PM »
Well. I figured out what the problem was. The pulse lengths for the Step and Directions were too low. The stepper driver board is opto-isolated, so I guess that the pulses need to be longer to get the signals to the motors. Everything is working fine now!! Is there a way to make the pulses longer than 25 us??
Thanks for everyone's help and suggestions on this sticky situation!! GO MACH3!
Reply #14 on:
April 17, 2007, 06:13:50 PM »
Have you tried Sherline mode? I am sure this is meant for drives that need increased pulse time.
Print
Pages:
1
2
Go Up
« previous
next »
