May 28, 2012, 12:47:11 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Mach3 and G-Rex
| | |-+  Jog X-axis, Jog Spindle Too?
Pages: 1   Go Down
Print
Author Topic: Jog X-axis, Jog Spindle Too?  (Read 1923 times)
driftdriver
Holding
Offline Offline
View Profile
« on: March 22, 2007, 01:26:35 AM »
First post here ...again! Grin
(Original post lost in the migration.)
After a fresh install of MAch3 r2.00.0059, G100 (v2.55) and shuttlepro plugins, and setup I decided to do a test run.
I pulled up the G100 Monitoring window and did a jog of the X-axis using the shuttlepro. I noticed something strange. Both the X-Axis and Spindle step counters were counting up.This doesn't happen with either the Y-axis or Z-axis, just the X-axis ( I misread the spindle counter for C-Axis in my original post.. definitely need new reading glasses:D).
Could I have made a mistake in the Config somewhere? And where to start looking?
[Usual Noob Disclaimers:D]
« Last Edit: March 22, 2007, 01:42:53 AM by driftdriver » Logged
cncguytoronto
Active Member
Offline Offline
View Profile
« Reply #1 on: July 20, 2007, 07:43:01 AM »
Hello,  I wish I could help you with your problem...but maybe you can help me with mine...I just purchased the shuttle pro yesterday...and I can get all the functions to work
exect for the Select X,Select Y, Select Z and the inner and outer knobs to job....So it looks like the plugin is working and enabled do I have to set anything else in the software to make it work.....I keep getting an error in the status "Unknown word where unary operation could be"
any input would be great
cncguytoronto
shane
Pages: 1   Go Up
Print
Jump to:
