May 28, 2012, 12:46:02 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  VB Script bug: LoadFile does not work right from the macropump
Pages: 1   Go Down
Print
Author Topic: VB Script bug: LoadFile does not work right from the macropump  (Read 1478 times)
jemmyell
Active Member
Offline Offline
View Profile WWW
« on: March 14, 2007, 03:20:08 PM »
The load does not complete and an empty path generation dialog is displayed which gets 'stuck'
-James Leonard
Jeff_Birt
Active Member
Online Online
View Profile WWW
« Reply #1 on: March 14, 2007, 08:12:28 PM »
Is the macropump script blocking?  Could it be that the script engine is trying to launch the macropump script again before the first instance in finished?
Happy machining , Jeff Birt
jemmyell
Active Member
Offline Offline
View Profile WWW
« Reply #2 on: March 15, 2007, 10:08:10 AM »
I do not believe that a second instance of the macropump is ever run.  I run a basically infinite loop inside the macropump and nothing I see tells me that the macropump is being launched again.
Art has confirmed the bug and will fix it in the next release.
-James
Jeff_Birt
Active Member
Online Online
View Profile WWW
« Reply #3 on: March 15, 2007, 11:21:44 AM »
James,  I watched the macropump video this morning and indeed Art does say that the macropump is blocking and will run to completion.
jemmyell
Active Member
Offline Offline
View Profile WWW
« Reply #4 on: March 23, 2007, 11:07:22 AM »
Hi, I just tested .059 and all is well now!
-James
Pages: 1   Go Up
Print
Jump to:
