Hello Guest it is June 09, 2026, 10:03:29 PM
Author Topic: VB Script bug: LoadFile does not work right from the macropump  (Read 9186 times)
The load does not complete and an empty path generation dialog is displayed which gets 'stuck'
-James Leonard
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: VB Script bug: LoadFile does not work right from the macropump
« Reply #1 on: March 14, 2007, 08:12:28 PM »
Is the macropump script blocking?  Could it be that the script engine is trying to launch the macropump script again before the first instance in finished?
Happy machining , Jeff Birt
« Reply #2 on: March 15, 2007, 10:08:10 AM »
I do not believe that a second instance of the macropump is ever run.  I run a basically infinite loop inside the macropump and nothing I see tells me that the macropump is being launched again.
Art has confirmed the bug and will fix it in the next release.
-James
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #3 on: March 15, 2007, 11:21:44 AM »
James,  I watched the macropump video this morning and indeed Art does say that the macropump is blocking and will run to completion.
« Reply #4 on: March 23, 2007, 11:07:22 AM »
Hi, I just tested .059 and all is well now!
-James
