February 09, 2012, 01:59:26 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  no motor movement - taig micromill
Pages: 1   Go Down
Print
Author Topic: no motor movement - taig micromill  (Read 2384 times)
connors934
Active Member
Offline Offline
View Profile
« on: March 13, 2007, 01:52:27 PM »
Hi all
Here's what I have:
Taig Micromill, a couple of years old, just upgraded to mach 3, xp computer, pentium III, 40 g hard drive, mostly empty
the motors are not responding to the keyboard jog.
Printer port is 0x378
The pinouts are set to
axis | step pin |  dir pin | dir lowactive |  step lowactive  | step port |  dir port
x       3           2          active low       active low                   1           1
y       5           4          active low       active low                   1           1
z       7           6           active low       active low                   1           1
Neither sherline mode or non works.
No motor response, except they twitch when I turn the computer on.
any suggestions?
Chris
connors934
Active Member
Offline Offline
View Profile
« Reply #1 on: March 13, 2007, 03:46:28 PM »
Here is where I got the info for the pin outs
http://www.cartertools.com/mill.html
Chris
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #2 on: March 14, 2007, 07:51:40 AM »
You also should try Sherline mode... ther drivers for the Taigs are a bit slow
Fixing problems one post at a time Wink
www.newfangledsolutions.com
www.machsupport.com
connors934
Active Member
Offline Offline
View Profile
« Reply #3 on: March 18, 2007, 08:25:07 AM »
Here are photos of the inside of the controller
One of the circuit boards says 2003
http://flickr.com/photos/connors934/423219757/
http://flickr.com/photos/connors934/423219639/
If this is not compatible with mach3, will it run with an older version, mach 2 or 1?
thanks a bunch
Chris
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #4 on: March 18, 2007, 08:43:32 AM »
do you have the pinout for the drive?
www.machsupport.com
connors934
Active Member
Offline Offline
View Profile
« Reply #5 on: March 18, 2007, 11:59:49 AM »
These are the pinouts I am using, info is from Nick Carter - http://www.cartertools.com/mill.html
Chris
az7733
Active Member
Offline Offline
View Profile
« Reply #6 on: March 24, 2007, 06:05:06 PM »
My step pins are even and dir pins are odd.
Robert
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #7 on: March 24, 2007, 10:38:47 PM »
That would be a problem Wink
www.machsupport.com
connors934
Active Member
Offline Offline
View Profile
« Reply #8 on: March 28, 2007, 04:57:42 AM »
The motor tuning settings that seem to work best are:
- all axes (except 4th, which has different value needs)
Step 32000 Vol 9.654 Accel 2.25 Pulse 0 Dir 0
- jog rate % 25 (it was set by default at 95%)
This allows it to jog from the keyboard, but it doesn't run code properly.
The scale is off x y and z and the speed is faster than the steppers can handle when it runs a file.
Chris
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #9 on: March 28, 2007, 05:27:01 AM »
You need to set your Max velocity to about 25% of what it is now. You do this under your motor tuning. If you can't run at 100% jog you will not be able to run a G00 (Rapid) move.
www.machsupport.com
Pages: 1   Go Up
Print
Jump to:
