Hello Guest it is June 08, 2026, 11:17:41 PM
Author Topic: Hidden toolpath  (Read 11518 times)
Hidden toolpath
« on: March 10, 2007, 01:40:09 PM »
I made a new profile of my own and I cannot see the worked toolpath in it. Config/Toolpath settings are the same than in the default profile, which is working fine. Any hints? Thank you.
Also the iconized tool is pretty big and not that transparent hiding a lot, are there more shapes to chose ?
Gianni
Re: Hidden toolpath
« Reply #1 on: March 10, 2007, 04:23:04 PM »
Look on the Diagnostics page and make sure the "Toolpath on/off" is switched on.
Re: Hidden toolpath
« Reply #2 on: March 11, 2007, 04:41:49 AM »
Display is on, anyway setting it to off hides everything from the tool display.
What's missing is the highlighted tool path while the tool is working. All the other paths, G1's, rapids, etc., are visible.
Gianni
Re: Hidden toolpath
« Reply #3 on: March 11, 2007, 04:51:16 AM »
Do you possibly have it in Jog Follow mode, dont think the toolpath gets highlighted in it.
Re: Hidden toolpath
« Reply #4 on: March 11, 2007, 06:44:09 AM »
No, I don't and yes, Jog Follow mode do shows higlhlited the last known point  (not in my new profile, unfortunately).
Gianni
Re: Hidden toolpath
« Reply #5 on: March 11, 2007, 07:28:23 AM »
can you post a screenshot of what you actually see?
Re: Hidden toolpath
« Reply #6 on: March 11, 2007, 12:11:10 PM »
Sure.  The upper is the standard profile, the lower the profile without milled path.
Gianni
