Hello Guest it is June 13, 2026, 01:50:17 AM
Author Topic: Can I pause between lines in VB  (Read 7304 times)
« on: February 22, 2007, 02:41:54 PM »
I am trying to write some macros for the lathe I am retrofitting. The gearbox utelises clutches and I dont want to change from, for example, full speed to a stop in one go. What I intend to do is write into my macro to look at the spindle speed and if it is too big a difference I will drop it down at least one  speed before I stop it. I need to be able to pause for a few seconds after I have shifted down before I then stop, is there a simple way to do this?
Re: Can I pause between lines in VB
« Reply #1 on: February 22, 2007, 06:45:13 PM »
I found something that will work I think, it was in the post about script consuming too much resources.
