Hello Guest it is June 09, 2026, 07:41:26 AM
Author Topic: X axis Step pin change during millig  (Read 7396 times)
JohnXYZ
« on: February 16, 2007, 04:41:00 PM »
Hallo everybody,
I am evaluating Mach 3 1.90.038 on my 3D mill machine, but I am having some trouble on X axis.
I load Gcode usually generated with siemens iso post processor, then I push Cycle Start, change the tool and the machine start
working fine on every axis.
After some lines of GCode X axis stop itself.
The first times i thought it was an hardware trouble, but after some checks I found that mach3 changed the value in my  Step pin from
 9 (my default value) to 10 or from 9 to 11, loosing the control of x axis.
Can anyone help me to understand why?
P.S. I'm using a notebbok PC with Pentium 4 1.6 Ghz and 256 Mb Ram
Thank you
Re: X axis Step pin change during millig
« Reply #1 on: February 23, 2007, 09:14:48 AM »
Download the newest Rev of mach3 from the Web and it will fix your problem.
www.newfangledsolutions.com
www.machsupport.com
