May 28, 2012, 12:39:32 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach SDK plugin questions and answers.
| | |-+  YADRO DRO Input Plugin
Pages: 1   Go Down
Print
Author Topic: YADRO DRO Input Plugin  (Read 2395 times)
laserted
Active Member
Offline Offline
View Profile
« on: February 10, 2007, 06:34:01 PM »
Greets - has anyone been actively persuing a plugin that would allow a Yadro-compatible (or other equivalent DRO kit with linear glass or capacitive scales/calipers) attachment via a serial port? I recall a few posts a long while back that didn't materialize anywhere. While it would be great to have closed-loop capability (even if only on a correctional or slow feed basis), the manual DRO function would be it's greatest asset. I realize that, especially if dealing with a servo system, multiple error-correcting inputs would be a challenge for a typical driver, so full closed-loop affecting the core of Mach3 and it's pulsing engine while a servo drive and its shaft encoder are chugging along may not be available....
Cheers,
Ted.
dandumit
Active Member
Offline Offline
View Profile
« Reply #1 on: April 12, 2007, 06:43:29 AM »
Sounds intresting. I would be intrested too !
Daniel
yellowdog
Holding
Offline Offline
View Profile
« Reply #2 on: July 02, 2007, 08:49:07 PM »
I have new glass scales and dro with rs232 outputs on my Bridgport.  I want to upgrade this mill to Mach3 or 4, are there any gadgets out there to do this with?  I'd sure hate to toss a grand out the window.
Pages: 1   Go Up
Print
Jump to:
