Hello Guest it is June 12, 2026, 05:27:10 AM
Author Topic: Plasma Guys -- need some advice  (Read 13672 times)
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
« on: February 07, 2006, 12:17:46 PM »
I have to have some pieces plasma cut for the mill I am building. I would like to know if I can plasma cut a 1/4 inch hole in 3/8 steel. Or will it just make a bad hole? what is the smallest you can cut vs plate thickness? This is a 200 amp pro plasma cutter at a steel fab shop.
chad
Re: Plasma Guys -- need some advice
« Reply #1 on: February 07, 2006, 02:40:06 PM »
I would drill all my holes that I could.... we did some 1/2inch holes in 1/2 plate that were okay but I would still drill...
Hope that is some help.
www.newfangledsolutions.com
www.machsupport.com
