Hello Guest it is June 12, 2026, 09:43:08 AM
Author Topic: Here is my plasma machine I am working on.  (Read 31681 times)
« on: January 22, 2007, 10:18:04 PM »
Hey guys,
Here are a few pics of the plasma table I am working on, should have the z stage done tomorrow and the plasma torch this weekend. Am planning on the campbell thc once I get all the bugs worked out. Feel free to make comments and suggestions.
ynneb
Re: Here is my plasma machine I am working on.
« Reply #1 on: January 22, 2007, 11:38:09 PM »
Thanks for the pictures. Its starting to look good.
I dont know much about the speed / acceleration / deceleration requirements for plasma, but if that were a router, you would find that the Y axis is not reduced enough.
You're doing well, keep up the great work.
« Reply #2 on: January 23, 2007, 12:23:00 AM »
Thanks ynneb,
I dont plan on putting a router in it but I built it heavy enough so I can upgrade to that if and probably when I decide to. For right now it should move the plasma torch fine but i will find out shortly, it is a 750 oz stepper on both x and y stages and a 425 for the z. Thanks again for the input.
Offline jeep534
  •  123 123
  • From the hills of WV
« Reply #3 on: January 23, 2007, 04:10:35 AM »
Cool,
    Looks like something I would like to build....... how do I / WE get more info.
Thanks for shareing
archie =) =) =)
Facebook archies machine
« Reply #4 on: January 23, 2007, 06:23:59 AM »
Looking good. The one thing I see that I don't like is the chain.
« Reply #5 on: January 23, 2007, 11:12:13 AM »
Well, as far as plans go I just built it using the plans in my head, I can get some info up on what i used for parts. This is my first attempt at a cnc machine, I have zero experience. Brett, what would u suggest instead of a chain, it is adjustable  but I do notice a little backlash but it is very minimal right now, I expect more as everything 'wears in'. I have put a pencil in it and it will draw at a pretty close tolerance, more then I need for the application I plan on using it for. It is going to be used mostly for signs. Thanks for the input, keep it coming.
« Reply #6 on: January 23, 2007, 01:17:21 PM »
Hey Dave,
    I'd try to replace the chain with a timing belt. These folks could help with the components.
http://www.sdp-si.com/
« Reply #7 on: January 23, 2007, 11:17:53 PM »
OK, here are a few bits of info on the table, like i said this is my first design so I wanted to be able to buy everything 'off the shelf' so it is easy to get parts. First of all the frame is 3" x 3" x 1/8" steel tube, I used 1" x 1" x 1/8" angle for the slat supports and the slats are 3" x 1/8" flat steel (cheap to replace). The table is 5' y (gantry) and 6' x inside measurements, gives me plenty of room for a 4' x 4' sheet. I squared and trued the table. The linear slides are from www.igus.com Drylin T for the x axis and Drylin W for the y and z axis, those are the most expensive parts for the machine. I used a fixed slide on the motor side and a floating slide for the other side, per the igus rep. I then used 1/2 plywood to 'mock' up the gantry sides to get all the placements right then machined then out of 12" x 12" x 1/2" steel and welded them to the gantry crossmember which is 2" x 6" x 1/8" steel. All the motors (2 - RHT34-740 oz/in (x and y) and 1 RHT34-425 oz/in for the z), Gecko g201 controllers, and all the power supply parts i ordered from www.homeshopcnc.com. The drive belts and pulleys and misc bearings are all from McMaster-Carr (www.mcmaster.com). Like i said this is my first attempt so I hope it works out, if not there is always rework!!! Hope I didn't miss anything, if so just let me know. Hope to have it cutting this weekend. All said and done, I should have about $2500-$2800 into it, that includes a cheap computer I got at Wal-Mart, didn't want anything fancy, I also Powdercoat and I get dust ALL over!! When it is all done I get to tear it all apart and Powdercoat the whole thing, gonna be hard to do when it is working :( Well, thanks for listening to me ramble, hope this is good info for anyone who in interested in a cheap table.
« Reply #8 on: January 23, 2007, 11:46:16 PM »
Hey Dave, sounds and looks like you are allmost there. Looking good. Keep us posted.
« Reply #9 on: January 23, 2007, 11:59:30 PM »
Got the z on tonight, had to come in and get the pinout on the stepper, seems I had a phase or 2 wired backwards. Ill throw the pic in anyways.
