May 28, 2012, 12:09:01 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  NC Pod (Moderator: kookaburra)
| | |-+  Probe function with NCpod
Pages: 1   Go Down
Print
Author Topic: Probe function with NCpod  (Read 3225 times)
rcrabb
Active Member
Offline Offline
View Profile
« on: January 20, 2007, 09:26:13 PM »
Is the probe function working with the NCpod? I haven't been able to do any probing with the pod. Any information???
Ryan
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #1 on: January 23, 2007, 07:56:59 AM »
It is nto working at this point... but it will at some point Smiley
Fixing problems one post at a time Wink
www.newfangledsolutions.com
www.machsupport.com
kookaburra
Active Member
Offline Offline
Fussy? Yep! That's Me ;)
View Profile WWW
« Reply #2 on: January 26, 2007, 06:13:01 PM »
The probing function is being worked on at the moment. There is probing in the pod at the moment but there is no ramping set with it so all probing will be either slow or inaccurate. As soon as the firmware is updated to allow Art to use a ramping facility in the firmware, it will be finised off and activated.
80% there.
Regards
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
"If you think you are under pressure - Try opening a sippy cup on an airoplane - 30,000ft in the air"
Greetings From Down Under
Dave Drain
Akela Noble Technologies Pty. Ltd.
timmycnc
Active Member
Offline Offline
View Profile
« Reply #3 on: August 18, 2008, 01:50:14 PM »
I  have installed my zero plate on the Ncpod + mach3, but it doesn't work.
is this only with my setup, or is this a firmware bug ?
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #4 on: August 18, 2008, 06:18:02 PM »
I honestly don't know if the NCpod is still being developed or dead in the water.  Sad
The probing as far as my experience goes does not work.
G31 move will head off in whatever direction it feels like at the time.  No rhyme or reason that I can find.
So unfortunately it is on the shelf. Replaced by the excellent SmoothStepper.
Greg
Pages: 1   Go Up
Print
Jump to:
