Hello Guest it is June 11, 2026, 11:52:56 AM
Author Topic: Documentation, Tips and Tricks  (Read 97118 times)
Offline kookaburra
  •  56 56
  • Fussy? Yep! That's Me ;)
    • Akela Website
« on: January 14, 2007, 09:08:44 PM »
Team,
This thread is for posting helpful Tips, fixes for known problems or documentation relating to the NC Pod. Please try to reduce the number of questions asked in this thread to keep it nice and clean and a good place to come for help. Please feel free, however, to let us know if one of the tips, fixes or documents, did not help ar needs adjustment so we can provide better support.
Kindest Regards
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
"If you think you are under pressure - Try opening a sippy cup on an airoplane - 30,000ft in the air"
Greetings From Down Under
Dave Drain
Akela Noble Technologies Pty. Ltd.
Offline kookaburra
  •  56 56
    • Akela Website
Re: Documentation, Tips and Tricks
« Reply #1 on: January 14, 2007, 09:21:19 PM »
Team,
Here is a preliminary connection diagram and setup document that will hopefully take some of the confusion out of connecting your pod for the first time. If there are any mistakes or if I have missed anything, please let me know.
www.cncteknix.com/ncpod/ncpod_diagram.pdf
Take it easy!!
« Last Edit: January 14, 2007, 10:43:12 PM by Chaoticone »
Dave Drain
Offline kookaburra
  •  56 56
    • Akela Website
USB Loss of Communications
« Reply #2 on: January 14, 2007, 10:11:26 PM »
There is a known issue regarding the loss of communications between Mach3 and the NC Pod.
1. Is USB 1 - Ensure that you are using a PC or Laptop with USB 2.
On some PC's and Laptop's the Pod will stop communicating after a certain number of minutes (or lines of code). So far, this problem has been fixed by going in to your computers bios. In the bios, you will see a mode for USB called "Legacy Mode". If it is enabled then that is more than likely the problem. To fix the problem, disable legacy mode and re-boot your computer, you should find that it will now have stable communication.
« Last Edit: January 14, 2007, 10:13:29 PM by kookaburra »
Dave Drain
« Reply #3 on: January 14, 2007, 10:47:22 PM »
Dave,
   Thanks to you and rcrabb I have these pics to help. If you want to delete, feel free.
