Hello Guest it is June 12, 2026, 05:28:51 AM
Author Topic: Logitrol &Mach2  (Read 14264 times)
Offline Bear
  •  15 15
Logitrol &Mach2
« on: February 05, 2006, 04:57:56 PM »
Hi, Bear here,
Has anyone instlled,use any of these units? Am trying to get a servo system up an running,having a nitemare of a time.Had it working on the table, then mounted it to machine and now I cant grt to work.Mach2 seemms to be outputing correctly( using RS232 inline gague). ???As Im not much of a computer or electrical wizz Im in over my head I think.Need any and all help I can get.
Thanks for your time.
  Bear
ynneb
Re: Logitrol &Mach2
« Reply #1 on: February 05, 2006, 09:20:40 PM »
I would contact logitrol for thier xml file to drop into Mach.
This would be the easiest solution.
http://www.lowcostcncretrofits.com/
tahliakeefe@dodo.com.au
Since they are recommending to use Mach 2, I would be surprized if they havnt already made an appropiate XML file for thier drivers.
The only thing you will need to then change is the steps per unit settings and any other input sensor devices you have added to your machine.
« Last Edit: February 05, 2006, 09:27:08 PM by ynneb »
Offline Bear
  •  15 15
Re: Logitrol &Mach2
« Reply #2 on: February 06, 2006, 02:05:54 AM »
Thanks,  Ynneb
Sometimes the oblivious is blinding.
E mail is on the way.
Bear
