Hello Guest it is June 10, 2026, 10:42:09 PM
Author Topic: output register (1040) over Modbus and VB  (Read 25416 times)
« on: January 09, 2007, 04:13:31 PM »
Hi all,
it´s my first post on the Forum, up to now I had in each case along-read.
To my person, I am German and am very bad with my English.
I am 36 years old and my hobby am cnc and electric.
I use a self-built modboard for mach3mill (of base the Homannboard) and have there a problem.
If I want to use the digital ones of digital-out´s  in a macro, I make with e.g. “aktivateSignal (output1)”
Then is in the address 1040 (Peter´s Protocol) bits 3 set (low byte of the integer Variable).
It possible also the upper bits (8-15) in the address is to be used 1040?.
I have it with aktivateSignal (output10) tried however without success.
I need this to use more as 8 LED on my MPG.
Is this possible, if how??
I hope it know which I write here and can help me.
thanks many !!!!
greeting Frank
Re: output register (1040) over Modbus and VB
« Reply #1 on: January 09, 2007, 06:18:41 PM »
Are you using the ModIO plugin? Or are you doing this in VB?
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: January 10, 2007, 12:35:29 AM »
Hi Brian,
I have with VB (macropump.m1s) tried.
The LCD output (20x4) the MPG and
the lower 8 Bit´s of the Adress 1040
are working correctly. The Macrocode for
the LCD is from the ModIO script (Peter´s Board)
thanks for helping
greetings Frank
« Reply #3 on: January 11, 2007, 10:10:37 AM »
I think you would be better off to use the plugin that John P did.. Pete H should have a copy, John did a GREAT job on it!
www.machsupport.com
« Reply #4 on: January 11, 2007, 11:43:23 AM »
Hi Brain,
I want to try it
greetings frank
« Reply #5 on: January 11, 2007, 03:13:38 PM »
Hi Brain,
with the Modbus Plugin too heavy for me, no function.
there is a documentation there ?
there is to make no possibility over VB?, is better for me.
greetings Frank
« Reply #6 on: January 13, 2007, 04:57:37 AM »
Hi Brian,
you have an example (e.g.Picture) which I must write there.
Greetings Frank
« Reply #8 on: January 14, 2007, 01:02:12 PM »
Hi Brian,
yes i´m see this, but i found no info´s of this Plugin.
the links which you sent me, do not show not like the Plugin are adjusted.
I have problems thereby.
A Pic of Setup-Window of this plugin, how see the adjusted
would be greatly .
thangs
greetings Frank
« Reply #9 on: January 14, 2007, 08:32:19 PM »
To get the plugIn you will have to mail Peter H. ... I don't have a copy, I just know there was one done.
www.machsupport.com
