Hello Guest it is June 11, 2026, 06:38:58 AM
Author Topic: Where is debounce interval located can't find it anywhere?  (Read 17353 times)
Where is debounce interval located. I've read on line that it needs to be high for the limit switches to work. But I can't find it anywhere.
Offline alenz
  •  137 137
Re: Where is debounce interval located can't find it anywhere?
« Reply #1 on: May 14, 2012, 11:54:20 PM »
Config>General Config - upper right corner.
« Reply #2 on: May 15, 2012, 12:27:14 AM »
That's what I thought but I don't have that as an option I have config. and no general config under that. Any thoughts.
« Reply #3 on: May 15, 2012, 01:06:06 AM »
You must have a very old version of Mach3 or you are using Mach2. You will have two options under that menu if you are using one of them, the options are logic and state if I recall. Afraid I cant remember which it is in if in fact there was such an option.
« Reply #4 on: May 15, 2012, 11:06:30 AM »
I do have Mach 3 but I think it's 07 or 08 ya it's pretty old. Should get a new version. It does have state and logic. I'm not in front of my computer, but does that have the debounce option in there or is it called something else
« Reply #5 on: May 15, 2012, 11:31:40 AM »
