Hello Guest it is June 09, 2026, 07:41:25 AM
Author Topic: Stepper freeze noise with higher driver kernel speed...  (Read 17339 times)
Re: Stepper freeze noise with higher driver kernel speed...
« Reply #10 on: May 14, 2012, 04:11:08 PM »
Not sure what you can't get over but sounds like your motors are skipping when using the 45 khz. So if the sent signal is bad the motor skips / misses steps and can do some wierd things. Could be as simple as that.
« Reply #11 on: May 14, 2012, 04:46:15 PM »
That noise is your stepper stalling.
