Hello Guest it is June 09, 2026, 04:26:21 AM
Author Topic: New 4 Axis Milling Screen Set (RaspScreen)  (Read 45156 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« on: January 05, 2007, 03:10:50 AM »
Hi All,
here is a part finished screen set for 4 axis milling, I have designed it to be clear, clean and simple, I am testing it for use on a 15" touch screen.
Put RaspScreen.set into the Mach3 folder
Put the RaspButtons folder inside Mach3\Bitmaps folder
PLEASE NOTE
The screen set is not finished and only part tested, load it and have a look but don't use it.
Any comments welcome.
Graham.
« Last Edit: January 04, 2009, 06:53:17 PM by Graham Waterworth »
Re: New 4 Axis Milling Screen Set (RaspScreen)
« Reply #1 on: January 05, 2007, 03:41:00 AM »
Hi Graham
Looking good - very industrial and functional. One thing I have noticed is that some of the LED buttons flicker of their own accord, I'm not sure whether they are meant to?. Also one thing I do like in normal Mach is the ability to simply Zero the DRO's are you planning to add this. I have a touch screen setup for my mill so when it's back together I would be very interested in trying this screenset. Keep up the good work.
« Reply #2 on: January 05, 2007, 03:53:38 AM »
Looks good Graham. :o
  •  2,785 2,785
« Reply #3 on: January 05, 2007, 05:31:55 AM »
Lots more to add yet but zeroing the dro's is one of them.
If you mean the opt stop led is flashing, I'm not sure why that is at the moment but I will fix it along with the rest of the problems
As I said its in a very early stage at the moment, but its always good to know what others think.  People come up with things I may have missed and after all the effort these things take its nice to think others would use it.
Graham.
« Last Edit: January 05, 2007, 05:41:43 AM by Graham Waterworth »
« Reply #4 on: January 08, 2007, 07:57:07 AM »
I think this screenset is going to be great for touch screens. When I have a minute I will try and load it up on the 15" touchscreen I have on my lathe and see how it 'feels' and the how the sizing is.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #5 on: January 09, 2007, 04:31:24 AM »
Just notice this new screen  :o
So that's how you make a good machine interface!
Great detail and work!
Did you model it around hardwear you already have?
  •  2,785 2,785
« Reply #6 on: January 09, 2007, 01:36:58 PM »
Thanks, praise indeed from a master.
Its not a copy of anything that I know of,  its more a case of how I think controls should be. Easy and un-cluttered.
Graham.
« Reply #7 on: May 10, 2008, 09:40:58 AM »
Graham,
Looks good little like black and white TV set from 70s :-))
I like clean design. Love to try on my mill then it finished as I steel cant get to understand this flash thing myself :-(
Ilia
Offline BOB88
  •  20 20
« Reply #8 on: June 12, 2008, 02:27:42 PM »
Hi Graham,
Have you done any more work on the RaspScreen since Jan. 5, 2007?  I downloaded that one and it's the most useable one I've seen so far.
I hope you'll complete it.
Bob
  •  2,785 2,785
« Reply #9 on: January 04, 2009, 06:58:13 PM »
Here is the latest version of my screen set, its still not complete but its getting there.
Just extract the zip file to your hard drive C: or where ever you have Mach3 located.
Graham
« Last Edit: January 04, 2009, 07:03:25 PM by Graham Waterworth »
