Hello Guest it is June 11, 2026, 06:38:19 AM
Author Topic: Mach intstalled to H:Drive instead of C:  (Read 6882 times)
Offline SMA
  •  68 68
« on: April 07, 2012, 12:31:43 AM »
Hey Guys,
Do to a partitioned hardrive reserved for Linux I had to install to H:.  Anyone see an issue with this.  I have seen in noted not to change the directory but I had no choice, except to get a new PC, but it still installs to the disk and remains intact.
The only issue I noted so far was that you had to change the directory to which edited Gcode was saved to.
S
Re: Mach intstalled to H:Drive instead of C:
« Reply #1 on: April 07, 2012, 02:37:59 AM »
Shouldnt be a problem, I have installed test versions to non default locations and its been fine.
