Hello Guest it is June 11, 2026, 01:08:23 AM
Author Topic: complex turnings  (Read 526518 times)
Re: radius
« Reply #10 on: January 09, 2007, 09:28:41 AM »
Chad on what cube do you want a description
Marcel
Re: radius
« Reply #11 on: January 09, 2007, 10:05:28 AM »
Here is one, it is a persimmon cube .875 square it as a spheroid a cube and a cube with points in the middle.On the following image you see a similar cube made in boxwood on its base and one that was cut to show all of its elements
« Last Edit: January 29, 2007, 10:46:28 AM by marcel beaudry »
Re: radius
« Reply #12 on: January 09, 2007, 10:28:36 AM »
For another chalenge this one is made in blackwood the lenght is 2.125 the spheres are .625 in diameter it contains a cube and a cube with spikes in the middle that is connected to the other sphere all made in one piece .
Marcel
« Last Edit: January 24, 2007, 08:48:39 PM by marcel beaudry »
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: radius
« Reply #13 on: January 09, 2007, 10:48:47 AM »
Very cool. Thats what confises most people, they cant understand how you do it, cuz they cant picture the tool.. :)
Re: radius
« Reply #14 on: January 09, 2007, 11:28:04 AM »
Hello Art
sometimes it is more difficult to make the tools than the cube . when you want to make a cube you have to think of only one step at the time, not the whole cube, just a step and what tool it's need.
Marcel
Re: radius
« Reply #15 on: January 09, 2007, 11:33:44 AM »
Hey Marcel,
    How much time do you have in the last picture you posted, tooling and all. It looks like you are a very patient man.
Nice work,
Amnz
Re: radius
« Reply #16 on: January 09, 2007, 11:44:19 AM »
WOW!  Truely Amazing!!!
John (bloy)
P.S.  Do you sell these?  I would love to....to.... to just have and to hold!  :)
« Last Edit: January 09, 2007, 11:47:13 AM by Amnz »
Re: radius
« Reply #17 on: January 09, 2007, 11:52:44 AM »
Hello Brett
to make the tool took me 2 hours the first time i made it of hss when i tried it on turning blackwood it only lasted to cut 3 faces before it became blunt i had to replace it with a carbide one wich took me another 3 hours the tool is only .050 wide and .500 long all tools are hand ground with diamond grinding wheels . And that is only one tool , the other on made in carbide is more complicated being l shaped the tip of the tool is only .079 wide while the body is .040 . Hope this helps. to turn a face takes about 59 seconds with mach 3 so total machining time 12 minutes and still that does not account for all the special jigs needed to hold and mark the positions of the faces.
Marcel
Re: radius
« Reply #18 on: January 09, 2007, 11:59:47 AM »
Yes they are for sale i have some i brass and some in aluminium that are made for key chain.and the others in wood.
Marcel
Re: radius
« Reply #19 on: January 09, 2007, 12:23:35 PM »
Yeap, I was right, you are a very patient man. These are amazing Marcel. I don't think anyone would mind if you put a post in the Bargain Basement section with some of these for sale.
