Hello Guest it is June 09, 2026, 02:36:55 AM
Author Topic: complex turnings  (Read 526164 times)
complex turnings
« on: January 04, 2007, 02:50:46 PM »
there are only two of them on photo they are hard to photograph the one shown is .625 on the side
Marcel
« Last Edit: November 06, 2007, 08:52:20 AM by marcel beaudry »
Re: radius
« Reply #1 on: January 04, 2007, 02:55:43 PM »
if i have the permission i can put more photos of metal and wood ornamental turning.This ornametal turning has three .375 cubes on the same spindle with two rings
« Last Edit: January 09, 2007, 09:26:27 AM by marcel beaudry »
Re: radius
« Reply #2 on: January 04, 2007, 03:11:17 PM »
You have my permission! LOL
Put the photos in the "Show "N" Tell" forum
Re: radius
« Reply #3 on: January 04, 2007, 03:16:51 PM »
this one made in brass 1.250 square turned on allsides with rings on all branches with a smaller cube in the middle
« Last Edit: January 04, 2007, 04:15:13 PM by Chaoticone »
Re: radius
« Reply #4 on: January 04, 2007, 03:24:52 PM »
this one made in brass1.250 as hemisphere on the end of the branches are bigger than the hole in the first cube (.625hemisphere) hole in the first cube .500 smaller cube .375
« Last Edit: January 04, 2007, 04:16:03 PM by Chaoticone »
Re: radius
« Reply #5 on: January 04, 2007, 03:26:29 PM »
i have two more photos but can only post 4
Marcel
Re: Re: radius
« Reply #6 on: January 04, 2007, 03:53:06 PM »
Post them in the "Show "N" Tell" forum.
Looky were here! ;D
« Last Edit: January 04, 2007, 04:13:37 PM by dfurlano »
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: radius
« Reply #7 on: January 05, 2007, 05:54:13 AM »
Those are very cool!! Could you describe the process for one of them.
BTW. you can post up to 4 photos per 'post' , not total.. ;)
Chad
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: radius
« Reply #8 on: January 08, 2007, 06:59:56 AM »
Marcel:
  OK, OK, Now your rubbing it in.. Those just arent possible... :-)
Art
(I am truly amazed, your a real craftsman...)
Re: radius
« Reply #9 on: January 09, 2007, 09:17:51 AM »
Hello Art
Here are some of the tools used to create those cube , sometimes i wonder if i should be showing the tools instead of the cubes. all the tools are .250 square
« Last Edit: January 09, 2007, 11:20:08 AM by marcel beaudry »
