February 12, 2012, 09:16:00 PM
Search:     Advanced search
+  Machsupport Forum
|-+  General CNC Chat
| |-+  Show"N"Tell ( Your Machines)
| | |-+  Eagle KM-750..Anilam Crusader GX-M
Pages: « 1 2 3 4 5 6 7 8 9 10 11 12 13 »   Go Down
Print
Author Topic: Eagle KM-750..Anilam Crusader GX-M  (Read 15876 times)
ardor
Active Member
Offline Offline
View Profile
« Reply #100 on: April 15, 2007, 03:07:29 AM »
Whilst working on the ACAD for the wiring I finally think I know something.
Being your basic gearhead +12v on the battery is hot, -12v is ground.  So when I see -12v, GND, and SHEILD, it all means connect to da frame.
Now I am beginning to see that's WRONG.
Back to the spagetti bowl
Someone hurry and tell me if I'm still fecked up, before I get this all rewired.
Ashby
There is no approved dental use for WD40
fdos
Active Member
Offline Offline
View Profile
« Reply #101 on: April 15, 2007, 06:11:31 AM »
-12v is the negative rail on a dual rail supply.  Not 0v or GND Wink
A dual rail 12v supply will normally have -12v  0v   12v
Wayne...
HillBilly
Active Member
Offline Offline
View Profile
« Reply #102 on: April 15, 2007, 09:37:57 AM »
Here is the battery equivilent. It should show you why your power supply would not like the way you had it wired.
Darek
ardor
Active Member
Offline Offline
View Profile
« Reply #103 on: April 15, 2007, 01:20:56 PM »
OK guys
Hope to have the wiring dwg done soon.
Soon = Mon or Tue.
Ashby
Back in the day, (1958) I put a 413 with a 12v starter in an old Plymouth with a 6v system.  Put a 12v battery in it and tapped the 3rd cell for 6v to run the junk in the car.
Whoa...a dual rail 6v.
Batteries didn't last long but it was the hottest thing on Woodward Ave.
Edit: If I look at that vista thing much longer I'm going to go batty............ or battier.  Put the tin foil hat on but that won't turn it off.
« Last Edit: April 15, 2007, 01:57:47 PM by ardor » Logged
ardor
Active Member
Offline Offline
View Profile
« Reply #104 on: April 15, 2007, 08:38:54 PM »
Here's what it looks like now.
* Anilam_Wiring.dxf (171.05 KB - downloaded 100 times.)
« Last Edit: April 16, 2007, 01:05:52 AM by ardor » Logged
ardor
Active Member
Offline Offline
View Profile
« Reply #105 on: April 18, 2007, 03:45:37 AM »
Hope REV 1 is easier on the eyes
* Anilam_Wiring_REV_1.dwg (115.73 KB - downloaded 69 times.)
ardor
Active Member
Offline Offline
View Profile
« Reply #106 on: April 20, 2007, 05:20:28 PM »
Thot you might just want to know who you are dealing with.
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #107 on: April 20, 2007, 07:44:03 PM »
 Grin
Ardor,
You are a mess.
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
ardor
Active Member
Offline Offline
View Profile
« Reply #108 on: April 22, 2007, 02:48:07 AM »
I have connected power to X axis only.  Using the Pixie diagnostics I can move the axis.  I can't move it with Mach 3.
Here's my xml file.
Ashby
* Anilam_Mach3Mill.xml (39.07 KB - downloaded 71 times.)
Guest
« Reply #109 on: April 22, 2007, 01:57:34 PM »
Ashby
 If you are just not getting a movement in Mach when trying to Jog with the keyboard then it is probably because you dont have the Jog Control enabled.
Pages: « 1 2 3 4 5 6 7 8 9 10 11 12 13 »   Go Up
Print
Jump to:
