Home
Downloads
Mach and LazyCam
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Known Bugs
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
February 12, 2012, 10:26:25 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
General CNC Chat
Show"N"Tell ( Your Machines)
Eagle KM-750..Anilam Crusader GX-M
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
Go Down
« previous
next »
Author
Topic: Eagle KM-750..Anilam Crusader GX-M (Read 15901 times)
HillBilly
Active Member
Offline
Re: Eagle KM-750..Anilam Crusader GX-M
Reply #80 on:
April 03, 2007, 06:39:04 AM »
Yes it is a f1. If you had a shielded wire coming from the second 502 D/A board your speed was probable handled completely in the CNC.
Do your tools have a retension knob or threaded for a draw bar?
Darek
ardor
Active Member
Offline
Reply #81 on:
April 03, 2007, 02:08:53 PM »
Retention knob.
That PDF that I posted for the PLC is a programming manual, no wiring details. ........Rats.
The OUT. SVO-ON supplies ground directly to the relay of which the other side is connected to +24v (no PLC invovled.).
Where does the 24v come from. The only 24v I see is from the power supply I took from the card cage. 24v on that isn't connected to anything yet.
Ashby
Last Edit: April 03, 2007, 02:14:01 PM by ardor
There is no approved dental use for WD40
HillBilly
Active Member
Offline
Reply #82 on:
April 03, 2007, 05:26:50 PM »
There is a 24V power supply right above your PCB 801 board ( The one with 3 icecube relays.)
My tools are threaded for a draw bar with a Kurt actuator ( 3/8" CP air hammer.).
Darek
ardor
Active Member
Offline
Reply #83 on:
April 03, 2007, 05:38:44 PM »
That's what I get for posting info from what we laughingly call my memory. The machine is only 50 ft. from the office. Too lazy to go look.
Ashby
So now I'm ready to whack a ribbon cable and connect an enable (1) from a pixie. From the drawing, the odd numbers on the connector are on one row and the even on the other?
Last Edit: April 03, 2007, 05:42:19 PM by ardor
HillBilly
Active Member
Offline
Reply #84 on:
April 03, 2007, 06:47:36 PM »
Here is the diagram for mine. I would imagine the CNC to PLC interface would be the same for both machines.
The rest of the diagram will be like using a map of Alabama get around in Georgia!
Darek
ardor
Active Member
Offline
Reply #85 on:
April 03, 2007, 08:05:27 PM »
How disturbing it is to me to have to display the level of my ignorance.
That sheet IS in my wiring diagrams.
Sending you a PM
Ashby
HillBilly
Active Member
Offline
Reply #86 on:
April 03, 2007, 08:48:38 PM »
Actually that is a good thing!
As far as ignorance, I would not be much help if you had a machining question.
Darek
ardor
Active Member
Offline
Reply #87 on:
April 07, 2007, 06:51:25 PM »
Now I'm trying to figure out my limit switches. I have 3 per axis, all Normally Closed . On the X........ X+ & X-(24V), overtravel (servo disconnect) My Accu-Step BO board has one lug for each axis, Labeled "LS". I have read the section in the Mach 3 users guide on limit switches and the documentation that comes with the BO board. Can't see that I can use 3 per axis with what I have. Still have to turn on coolant after I (we) get this down.
I have another printer port. If I need another BO board I'd appreciate a recomedaton or two. Doesn't seem that I would need anything as fancy as what I have.
Ashby
EDIT: Could I use the XYZ minus switches as Home?
Not disconnect, run a jumper from NC contact on switch to LS lug on BO board?
Don't forget >>> I'm easily confused.
P.S.
Merry Christmas
Happy New Year
Have a nice Easter.!!
Last Edit: April 08, 2007, 08:30:40 PM by ardor
ardor
Active Member
Offline
Reply #88 on:
April 09, 2007, 04:13:41 AM »
Darek
I tried NC contact to BO board as above. No joy.
The BO board wants to see a connection to ground broken by the limit sw. The 24v negative from the power supply isn't connected to chassis ground.
So if I connect limit sw NC to BO board AND power supply 24v negative will that work ??
Or will that mess up PC board 803 ?
Ashby
Last Edit: April 09, 2007, 04:17:58 AM by ardor
HillBilly
Active Member
Offline
Reply #89 on:
April 09, 2007, 05:31:13 AM »
This is how mine are setup. If yours are the same, I would leave the middle switches as is ( This is the loop that kills the servos.).
The RED (X+), GRAY (X-), ORN (Y+) and YEL (Y-) will be the inputs to the board. The BRN wire that supplies +24v to the switches will have to be switched to ground now.
Darek
Last Edit: April 09, 2007, 05:41:29 AM by HillBilly
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP motion controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Loading...
