Home
Downloads
Mach and LazyCam
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Known Bugs
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
February 12, 2012, 09:57:22 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
General CNC Chat
Show"N"Tell ( Your Machines)
Eagle KM-750..Anilam Crusader GX-M
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
Go Down
« previous
next »
Author
Topic: Eagle KM-750..Anilam Crusader GX-M (Read 15891 times)
ardor
Active Member
Offline
Re: Eagle KM-750..Anilam Crusader GX-M
Reply #70 on:
March 31, 2007, 01:20:41 AM »
My breakout board is Accu-Step. When I wired step/direction to Arturo's spindle control board I wired them to axis 4 on the BO board. Couldn't see anywhere else, but it doesn't seem right.
Edit:
After staring at the BO board for an hour or so, I figured that enabling axis A on motor tuning and setting step to 5 & dir to 9 on pport 1 should to the trick.
Also.
If you tie the error lines of the Pixies together, as suggested in the PDF, a fault on one axis will shut down all the Pixie's. This should allow the use one Pixie ENABLE output for OUT. SVO-ON.
you may need a driver transistor if the Pixie can not sink the relay current
Can I tie the 3 enable lines of the Pixies together to connect to OUT. SVO-ON? Would that help to sink the current?
Ashby
Last Edit: March 31, 2007, 02:48:22 AM by ardor
There is no approved dental use for WD40
HillBilly
Active Member
Offline
Reply #71 on:
March 31, 2007, 09:36:17 AM »
If you do not have a back gear (low range). You must have some kind of special spindle motor/drive combination to have power at low speeds.
I planned on doing away with the PLC on mine and using basic Mach outputs.
When you go to fire this thing up with the OUT. SVO-ON signal. I would suggest you take the high voltage/motor connector off of the drives and verify you have the high power first. Then I would hook one drive up at a time, X first since it has the longest travel and put it mid travel. If A and B are reversed the axis will run away. If you ever had one of the toothed encoder belts go out you will know what I mean.
Darek
ardor
Active Member
Offline
Reply #72 on:
March 31, 2007, 02:12:12 PM »
"You must have some kind of special spindle motor/drive combination to have power at low speeds."
The spindle motor is AC, the drive is a Yaskawa Varispeed 626MTIII
Ashby
ardor
Active Member
Offline
Reply #73 on:
March 31, 2007, 07:42:19 PM »
Quote from: HillBilly on March 31, 2007, 09:36:17 AM
Darek
I vote for that. Is what I'm about to do with OUT. SVO-ON going to communicate with the PLC? If so, then how to turn the drives on otherwise.
Ashby
HillBilly
Active Member
Offline
Reply #74 on:
April 01, 2007, 05:42:51 AM »
The problem with connecting the enables together is one will have less resistance and take the majority of the load. If one wound up being the only one on it would take all of the load.
The OUT. SVO-ON supplies ground directly to the relay of which the other side is connected to +24v (no PLC invovled.).
The PLC decoded the information coming from P4. When the PLC sees a STROBE T,M or S it reads the data on SMT-0 thru 7 and applies it to that function. The latch signals tells the PLC the CNC will be waiting for the FINISHED(In) signal.
T=Tool
M=Misc. Function
s=Spidle Speed
Input P11-20/FEED STOP(IN) comes from the PLC also.
Darek
HillBilly
Active Member
Offline
Reply #75 on:
April 01, 2007, 05:46:09 AM »
Does your wiring diagram show the I/O side of the PLC. This is where you would interface Mach's I/O. From your spindle description this part of your machine will be alot different than mine.
(Edit/posted here to get rid of duplicate post)
Darek
Last Edit: April 01, 2007, 01:50:50 PM by HillBilly
ardor
Active Member
Offline
Reply #76 on:
April 01, 2007, 11:55:11 AM »
I have removed the card cage and GXM Console. Mounted the power supply from the card cage and have only run 5v from it to the BO board. Have not connected any of the other outputs of that PS anywhere.
If the PLC needs info from P4, it's not connected to the card cage or the console anymore.
Are we working towards not using the PLC?
Ashby
Last Edit: April 01, 2007, 07:10:32 PM by ardor
ardor
Active Member
Offline
Reply #77 on:
April 02, 2007, 03:34:52 AM »
Here's pix of the PLC and Spindle Control. The PDF manuals are to big to post here, so if you want to get them, I posted them
here-->>
http://wwbizz.com/Anilam/Darek
The PLC I have is F160MR, the only manual Mitsubishi had was for F2, they said that they were very similar.
The dwgs that I have don't show the I/O of the PLC.
Ashby
Last Edit: April 02, 2007, 03:50:51 AM by ardor
HillBilly
Active Member
Offline
Reply #78 on:
April 02, 2007, 01:51:30 PM »
You know " I have all the PLC I/O information." would have been the preferred answer!
Parts orientation must be how they kept up with the different models. I noticed your PLC is sideways. Mine is upside down.
If your spindle is single speed, I can't figure out what they used all the I/O for?
Darek
ardor
Active Member
Offline
Reply #79 on:
April 02, 2007, 03:38:55 PM »
There was a read out of spdl speed on the console & I could bump the speed up or down from the console, maybe that's what a bunch of the I/O was about.
Is your PLC f1?. I can't make it out on the pic.
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP motion controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Loading...
