February 12, 2012, 10:26:56 PM
Search:     Advanced search
+  Machsupport Forum
|-+  General CNC Chat
| |-+  Show"N"Tell ( Your Machines)
| | |-+  Eagle KM-750..Anilam Crusader GX-M
Pages: « 1 2 3 4 5 6 7 8 9 10 11 12 13 »   Go Down
Print
Author Topic: Eagle KM-750..Anilam Crusader GX-M  (Read 15901 times)
HillBilly
Active Member
Offline Offline
View Profile
« Reply #30 on: January 08, 2007, 11:26:27 AM »
The head on mine is different than yours also. It has the variable speed pulleys. There were M codes that basically run the speed adjustment from one end to the other with an air motor in high and low gear ranges. This provided 4 separate ranges and the spindle inverter varied the speed with in them.
Example:
M41....60-165
M42....166-499
M43....280-1,469
M44....1,470-4,640
The inverter speed control is analog 0-10v also. I plan on doing away with the PLC. It was setup to handle the few M codes. The Original control was setup to do a MST transfer function to the PLC.
Darek
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #31 on: January 08, 2007, 01:09:58 PM »
Your setup is much like the one that I have on my eagle Smiley I have a DL06 with an analog card running the VFD.
Fixing problems one post at a time Wink
www.newfangledsolutions.com
www.machsupport.com
HillBilly
Active Member
Offline Offline
View Profile
« Reply #32 on: January 08, 2007, 03:00:45 PM »
Mine has a larger motor on the X axis, which I thought was unusual. They are all made by SEM.
Darek
ardor
Active Member
Offline Offline
View Profile
« Reply #33 on: January 08, 2007, 06:56:35 PM »
Now I'm getting ready for the pixie's.  I have taken a 300W power supply out of an old computer. I want to use it to supply 12v+ and 5v+ to the pixie boards.
The guys over at the skyko forum say that it should be plenty to run the boards.  I posted this question there, but they aren't as active as we are here.
Any ideas how I can turn it on without being connected to a mobo?
When I plug it in and turn it on the 5v leads are active.
onsa
Edit: Breakout board just arrived. Grin Grin Grin
« Last Edit: January 08, 2007, 06:59:42 PM by ardor » Logged
There is no approved dental use for WD40
Guest
« Reply #34 on: January 08, 2007, 08:24:15 PM »
Think its the green wire to the ground next to it in the ATX plug but will get back in a few mins with a definitive answer.
Guest
« Reply #35 on: January 08, 2007, 08:26:03 PM »
Yes green wire to any of the grounds(BLACK) next will switch on the PSU, you will need a latching switch because as soon as you release them the power supply will stop.
ardor
Active Member
Offline Offline
View Profile
« Reply #36 on: January 08, 2007, 08:54:06 PM »
It has a switch next to the 110, so I'll connect the green to a black.  Switch off = shut down, switch on = go.
OK?
This is handy     http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm
« Last Edit: January 08, 2007, 09:40:38 PM by ardor » Logged
fdos
Active Member
Offline Offline
View Profile
« Reply #37 on: January 09, 2007, 12:36:31 PM »
Wayne,
That looks like a nice card Smiley
Brian I got one reserved for me to play with when they are available.   Want to take a look at this option then?  Might just be a viable alternative to the Galil cards.
Wayne...
Guest
« Reply #38 on: January 09, 2007, 02:42:23 PM »
OK?
If you are meaning the switch on the back of the PSU then you will need to undo the mains connection on it and join them together internally, then you could use the switch for the power on and ground wire on the ATX connector. Personally I would leave the switch the way it is and just add another switch or you could even just cut the green and black wire and connect them together permanantly and control the on/off by using the mains switch on the back of the PSU. Another option would be to just put a small jumper wire into the ATX plug, this would then be easy to remove if you ever needed to put the power supply back into service for a computer.
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #39 on: January 09, 2007, 07:21:22 PM »
Wayne do you have a link that I can have a look at? Art and I have to get the delta tau stuff up and running but after that Smiley
www.machsupport.com
Pages: « 1 2 3 4 5 6 7 8 9 10 11 12 13 »   Go Up
Print
Jump to:
