Home
Downloads
Mach and LazyCam
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Known Bugs
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
February 12, 2012, 10:29:43 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
General CNC Chat
Show"N"Tell ( Your Machines)
Eagle KM-750..Anilam Crusader GX-M
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
Go Down
« previous
next »
Author
Topic: Eagle KM-750..Anilam Crusader GX-M (Read 15903 times)
ardor
Active Member
Offline
Re: Eagle KM-750..Anilam Crusader GX-M
Reply #10 on:
January 06, 2007, 07:38:01 PM »
Got my Dell back from my daughter & have loaded Mach 3 R1.84.002.
Copied the xml file from the other box
Bought licenses from Newfangled for Mach & Newfangled.
Ordered this board from Ed Gilbert
Homing Accuracy and High
Speed Opto Isolation from
the Parallel Port
Should be here soon.
There is no approved dental use for WD40
DennisCNC
Active Member
Offline
Reply #11 on:
January 06, 2007, 08:55:17 PM »
Are you going to use one of these with the original drives?
http://www.skyko.com/products/
ardor
Active Member
Offline
Reply #12 on:
January 06, 2007, 09:13:45 PM »
Quote from: DennisCNC on January 06, 2007, 08:55:17 PM
I thought that the board from Ed wouldn't need anything else, that it could work with the original drives. Am I wrong?
Guest
Reply #13 on:
January 07, 2007, 03:43:52 AM »
Depends what the original drives are, if they accept step and direction signals then they will probably work, if they need analogue signals then you will need either different drives or the pixies etc.
ardor
Active Member
Offline
Reply #14 on:
January 07, 2007, 04:01:10 AM »
Quote from: Hood on January 07, 2007, 03:43:52 AM
OK, how do I figure out what the original drives need?
Your keeping me busy between this thread and the touchscreen/lathe.
Guest
Reply #15 on:
January 07, 2007, 04:07:32 AM »
Well you are going to have to find their specs. They kind of look similar to the ones that were in my Lathe, they were HiAks, if they are then I think they are analogue. Find the specs and you should get that info, then if they are analogue the pixies should work for you and it would be cheaper than getting new drives, also you know these drives are suited to your motors so best to try and keep them. I have no experience with the pixies so it might be worth doing some searching on CNC Zone to see what you can find out.
ardor
Active Member
Offline
Reply #16 on:
January 07, 2007, 04:15:56 AM »
Darek aka Hillbilly has a mill just like mine, he used to do retros and has given me some info lately. If he doesn't see this I will try to get in touch with him.
Guest
Reply #17 on:
January 07, 2007, 04:18:47 AM »
Dont wait, send him a PM
fdos
Active Member
Offline
Reply #18 on:
January 07, 2007, 04:44:40 PM »
The drives will be analogue velocity signal or at least normally on commercial machines they will be 99.9% of the time.
If the drives are good, then you will need some data and 3 of the Skyco cards to convert step/dir to a velocity command . These seem to have a good reputation, and are cheaper than most alternatives.
As Brian said above you could go the whole hog and put Brushless drives and motors on, but that will cost a fair bit. I see his point, but don't really agree that it's mandatory to making a machine reliable. Brushed systems are equally reliable, but never quite as fast and do every few years require their brushes changed.
400"/min is doable with brushed motors as your original setup proves. Going much faster would be pretty pointless and scary on an open machine like yours, I'm used to 1500"/min machining centres and even they make me twitchy sometimes!
The limiting factor on your speed will be the resolution of your encoders and the availble pulse rate from Mach.
Have you looked to see what encoders you have?
Wayne....
ardor
Active Member
Offline
Reply #19 on:
January 07, 2007, 04:54:24 PM »
Quote from: fdos on January 07, 2007, 04:44:40 PM
Wayne....
The encoders are Sumtak opticoders. 635 p/r 0.200" lead on the screws 3175 pp inch
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP motion controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Loading...
