Hello Guest it is June 13, 2026, 08:16:23 AM
Author Topic: Wont home with scale attached  (Read 7704 times)
« on: December 29, 2006, 10:58:22 PM »
OK, I finally replaced the head in my X axis linear scale that I smushed a few weeks ago. Its a 50800 line per inch reader head. A little overkill... ::)
 The machine has been running good up until tonight. Heres whats going on...
I went to home all axis. Z goes, Y goes, X goes a random distance and just stops and zeros.. huh? Hit home again. Z OK, Y OK, X moves randomly and stops and zero. more huh? ???
Disconnect scale. X homes normally. Double huh?
Reconnect scale... X only moves randoms distance towards home. If I keep hitting x ref it will eventually get there an hit the home switch and comes off.
Any ideas? I am watching the input leds when it moves and stops and none come on.
Re: Wont home with scale attached
« Reply #1 on: December 29, 2006, 11:12:11 PM »
ahhh... forget it.
I moved the X home to another port and the problem went away. Must of been some cross talk in the interface board.
