Hello Guest it is June 11, 2026, 01:33:10 PM
Author Topic: Available serial commands?  (Read 12996 times)
Offline fdos
  •  326 326
« on: December 29, 2006, 05:59:33 PM »
Any of the Mach VB guru's know if Mach can now recieve data on the rs232 port?
I know it's possible to send with SendSerial command, but did Rx ever get implemented?
Wayne....
Re: Available serial commands?
« Reply #1 on: December 29, 2006, 10:26:42 PM »
Nope :(
www.newfangledsolutions.com
www.machsupport.com
Offline fdos
  •  326 326
« Reply #2 on: December 30, 2006, 08:04:30 AM »
Brian
Thats a real shame..   I could be able to do so much more with my homebrew PLC if I could pass verbose messages back to Mach.
I guess I'll have to continue using an input for Acknowlage which has it's drawbacks.
Wayne....
« Reply #3 on: December 30, 2006, 09:40:37 AM »
If you set up to run over modbus you can do it :)
www.machsupport.com
Offline drew
  •  79 79
« Reply #4 on: December 30, 2006, 10:13:21 AM »
So if I want to set my VFD by serial command I can only send the command and I can't receive the reply.
If I had something important to say it would be here.
Offline fdos
  •  326 326
« Reply #5 on: December 30, 2006, 10:40:17 AM »
Yes I know about that archaic Modbus Protocol ;)   Maybe I'll go that route unless something better comes along.
It's just I have a simple PIC based I/O controller that costs next to nothing to make (<$10) , has as much I/O as you could wish for and can be programmed in Basic.
Is there any reason in particular that RS232 Rx is not supported?
Wayne....
« Reply #6 on: December 30, 2006, 04:54:47 PM »
No just that we are done working on new stuff for mach3 and are now working on Quantum. Mach3 is finished other then bug fixes  ;D
www.machsupport.com
