Hello Guest it is June 09, 2026, 12:05:17 PM
Author Topic: sped between cuts  (Read 6391 times)
sped between cuts
« on: February 01, 2012, 11:49:00 AM »
1. Is there a way to increase speed between plasma cuts?????
Cutting is at 1200 mm / min and mmmmmmving from one cut part to another is 1200 mm/min too
Can i change the moving speed ?
2. When i cut the toch is lifting from 1,5 mm to 4 mm. But if the metal sheet is bent then when not cutting the THC is not sensing the sheet and 4 mm in a point may be -2 mm in another point and torch is touching the metal sheet. Can I increase lifting height?
I'm using sheetcam an mach
For now i'm using Mach3 Flame with THC postprocessor
I have capacitive THC
Re: sped between cuts
« Reply #1 on: February 01, 2012, 12:23:38 PM »
You would set your MAX rapid speed in MACH3 config motor tuning.
You would set the Rapid (travel) Height in Sheetcam.
