Hello Guest it is June 11, 2026, 10:05:41 AM
Author Topic: Speed & feed calculator  (Read 16668 times)
« on: January 26, 2012, 05:58:38 PM »
Looking for an easy to use speed & feed calculator.  Any suggestions?
Re: Speed & feed calculator
« Reply #1 on: January 26, 2012, 06:31:46 PM »
« Reply #2 on: January 26, 2012, 08:04:48 PM »
Wow!  That's a handy tool for the money, but their feed/speed calculations are crazy conservative!  They give numbers for carbide endmills that are less aggressive than what I normally use for HSS!  I would take the feed rates it calculates and multiply by at least 2 or 3!
« Reply #3 on: January 27, 2012, 12:23:40 AM »
Hi All
I made this one up using Excel (You can change it)
It may help you if you want to make one up for a specific machine
If your machine has fixed feed rates you can edit the sheet and enter them.
http://www.mediafire.com/file/uxje635gjl5psee/SPEEDS and FEEDS - V2.zip
John
« Last Edit: January 27, 2012, 12:39:51 AM by John Mac »
« Reply #4 on: January 27, 2012, 05:10:48 AM »
Hi All
Image of speed and feed calculator above:
John
