May 28, 2012, 11:02:14 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  FAQs
| | |-+  how to get my old license number
Pages: 1   Go Down
Print
Author Topic: how to get my old license number  (Read 236 times)
Abrian1937
Active Member
Offline Offline
View Profile
« on: January 24, 2012, 10:51:33 AM »
My other computer died. I downloaded the demo and it said to go to Newfangled for my license number. I don't know how to get my old license number so I can continue. My new computer will not run my steppers and I am pretty sure I configured ports and pins and motor tuning that was running before. Help
Tweakie.CNC
Active Member
Online Online
Super Kitty.
View Profile WWW
« Reply #1 on: January 24, 2012, 11:06:08 AM »
Contact License support license@machsupport.com with your details they will have a record and send a duplicate license if everything is in order.
If you can read your old HD then your .xml file (usually Mach3Mill.xml or whatever profile you had been using) will have all your old settings.
Hope this helps,
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
scottn
License Biatch
Administrator
Offline Offline
View Profile
« Reply #2 on: January 24, 2012, 11:47:18 AM »
Albert,
I have just sent you a PM...
scott
Abrian1937
Active Member
Offline Offline
View Profile
« Reply #3 on: January 24, 2012, 04:42:13 PM »
Thanks Scott. I very seldom open Gmail that is why I didn't get your message. I will in the future.
Another problem is that I cannot get any pulse frequency on the diagnostics page on Mach3Mill. I am fairly sure that I have the correct pins and ports correct. Is there any way to activate that?
stirling
Global Moderator
Offline Offline
UK
View Profile WWW
« Reply #4 on: January 25, 2012, 12:15:48 PM »
There you go Abrian - a post of your own rather than mixed in with someone elses... (hijacked)
Pages: 1   Go Up
Print
Jump to:
