May 28, 2012, 10:55:01 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  home switch
Pages: 1   Go Down
Print
Author Topic: home switch  (Read 119 times)
daniellyall
Active Member
Offline Offline
View Profile
« on: January 20, 2012, 06:04:30 PM »
can anyone tall me does mach3 home to one axis at a time when you click on home button as have a g540 that has 4 inputs and what to have home switch, softlimits and a probe
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: January 20, 2012, 06:09:43 PM »
Mach by default homes one axis at a time, if you have seperate home switches for each axis you could home all at the same time or any combination of axis at the same time.
Normally however people just connect their homes in series and just use one input for them, in fact most have the limit switches set to be also home switches.
daniellyall
Active Member
Offline Offline
View Profile
« Reply #2 on: January 20, 2012, 06:18:22 PM »
thank you i will do that
Pages: 1   Go Up
Print
Jump to:
