May 28, 2012, 10:52:12 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  SmoothStepper USB (Moderator: Warp9TD)
| | |-+  SS does not back off of home switch
Pages: 1   Go Down
Print
Author Topic: SS does not back off of home switch  (Read 333 times)
rwskinner
Active Member
Offline Offline
View Profile
« on: January 19, 2012, 10:11:52 AM »
I have a smoothstepper and homing is working fine for XYZ Axis but on my C Axis, after it homes, it backs off just a tad and leaves the home switch acivated.
I can watch the Home LED and when it backs off the C I never see the LED go off.  C is a large rotary axis so it takes numerous steps to back off.
BTW, It's an optical interruptor switch H21A1.
Is there a fix for this other than me editing each and everyone of my Home Button Scripts for all my screens?
Richard
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: January 19, 2012, 10:18:13 AM »
Try setting a small filtering value in the SS config, maybe the min of 1.43.
rwskinner
Active Member
Offline Offline
View Profile
« Reply #2 on: January 19, 2012, 12:55:58 PM »
Sorry, I already had tried that and as well as 2.8
Richard
Active Member
Offline Offline
View Profile
« Reply #3 on: January 19, 2012, 02:03:15 PM »
Could you just connect a wire to simulate the switch and home that axis keeping the switch open/closed after it has been triggered to see if Mach continues to reverse off the imaginary switch. That would at least let you know if its a Mach/SS issue or a noise issue.
Pages: 1   Go Up
Print
Jump to:
