Hello Guest it is June 12, 2026, 04:58:34 AM
Author Topic: SS does not back off of home switch  (Read 10692 times)
« on: January 19, 2012, 09:11:52 AM »
I have a smoothstepper and homing is working fine for XYZ Axis but on my C Axis, after it homes, it backs off just a tad and leaves the home switch acivated.
I can watch the Home LED and when it backs off the C I never see the LED go off.  C is a large rotary axis so it takes numerous steps to back off.
BTW, It's an optical interruptor switch H21A1.
Is there a fix for this other than me editing each and everyone of my Home Button Scripts for all my screens?
Richard
Re: SS does not back off of home switch
« Reply #1 on: January 19, 2012, 09:18:13 AM »
Try setting a small filtering value in the SS config, maybe the min of 1.43.
« Reply #2 on: January 19, 2012, 11:55:58 AM »
Sorry, I already had tried that and as well as 2.8
Richard
« Reply #3 on: January 19, 2012, 01:03:15 PM »
Could you just connect a wire to simulate the switch and home that axis keeping the switch open/closed after it has been triggered to see if Mach continues to reverse off the imaginary switch. That would at least let you know if its a Mach/SS issue or a noise issue.
