May 28, 2012, 10:47:31 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Question on "Zerp World"
Pages: 1   Go Down
Print
Author Topic: Question on "Zerp World"  (Read 156 times)
Fred_evans
Active Member
Offline Offline
View Profile
« on: January 16, 2012, 12:55:09 AM »
To the experts -
thank you for your kind advice. I never used the video tutorials until
you suggested that i do and now I realize how much further i could
have been if i had used the video tutorials. The one I have watched are comprehensive, easy yo understand
and very educational.
Just a question about " zero world"
If i zero world does it also reset the home position that was set with home x and home z ??
regards fred
think of the trees-- use both sides of the computer paper
Global Moderator
Offline Offline
View Profile
« Reply #1 on: January 16, 2012, 06:03:50 AM »
The Zero World buttons, found on Turns manual screen, resets the axis position to 0 and will clear /remove any work offsets.
Fred_evans
Active Member
Offline Offline
View Profile
« Reply #2 on: January 16, 2012, 01:26:09 PM »
but does the "Home" position as set by set home remain untouched?
thanks Rich
Global Moderator
Offline Offline
View Profile
« Reply #3 on: January 16, 2012, 06:40:58 PM »
The home position will be lost since by clicking the Zero World button you are telling Mach that the current position in Machine coordinates is now
at a different location. So you would need to define where your new home position is.  Home can be anywhere.  Think of it as cleaning everything and starting from scratch.
Fred_evans
Active Member
Offline Offline
View Profile
« Reply #4 on: January 17, 2012, 03:40:22 AM »
thanks Rich
regards from South africa
Pages: 1   Go Up
Print
Jump to:
