Hello
Guest
it is
June 10, 2026, 03:11:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Upgraded to new hardware, Turn won,t run
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Upgraded to new hardware, Turn won,t run (Read 6605 times)
milehigh51
13
on:
January 15, 2012, 10:53:43 PM »
Hi All
I upgraded to new hardware MB AMD 145 Single core processor.
When I load Mach3 Turn it locks up the CPU. Mach3 mill loads fine.
I have tried several versions of mach with the same results
Thank You
Roy
Carnoustie, Scotland
Re: Upgraded to new hardware, Turn won,t run
Reply #1 on:
January 16, 2012, 02:05:32 AM »
Do you have any brains or a macropump or any plugins in Turn that you dont in mill? Do you have a high kernel chosen in Turn?
If you attach your xml I will have a look and see if I can spot any issues.
milehigh51
13
Reply #2 on:
January 17, 2012, 08:15:14 PM »
Hi Hood
Thanks for the reply. I did find the problem. In the bios disabled the following
secure virtual machine
power now
acpi srat table
C1E
This mother board is a Biostar AMD 3 chip set.
I hope this may help someone else.
Roy
Print
Pages:
1
Go Up
« previous
next »
