May 28, 2012, 10:46:44 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Machscreen Screen Designer (Moderator: Klaus1311)
| | | |-+  DRO Question
Pages: « 1 2   Go Down
Print
Author Topic: DRO Question  (Read 422 times)
rwskinner
Active Member
Offline Offline
View Profile
« Reply #10 on: January 16, 2012, 12:04:35 PM »
A couple more small issues.  See attached screenshot.
All the labels should be the same font and color but one acts like it's in bold. "Z Down Feed"
Also, the UserDRO's have the last digit overlapping the right side of the frame.
Is there anything that can be done to fix those items?
Richard
ger21
Global Moderator
Online Online
View Profile WWW
« Reply #11 on: January 16, 2012, 01:54:53 PM »
The "bold" font is a limitation of the way Mach3 displays text. The smaller the text, the more likely it will display "funny". Can you post the .set file so I can look at those DRO's?
rwskinner
Active Member
Offline Offline
View Profile
« Reply #12 on: January 16, 2012, 02:05:29 PM »
Okay....  Why only that one looks bold?
Here is the screen, page 11.
* Screen1.set (99.97 KB - downloaded 5 times.)
ger21
Global Moderator
Online Online
View Profile WWW
« Reply #13 on: January 16, 2012, 02:31:15 PM »
How it looks can change depending on where it is on the screen. All the text on my screen is done with
I won't be able to look at the screen for a couple hours, but I'll let you know what i find.
ger21
Global Moderator
Online Online
View Profile WWW
« Reply #14 on: January 16, 2012, 04:55:17 PM »
It's not the User DRO's, it's any DRO without a "skin".
When you add the skin, it shifts the numbers to the left.
Now, to get rid of that overlapping border, go to General Config and Uncheck "Boxed DRO's and Graphics". Not sure why it overlaps the numbers, I guess you could call it a minor display bug.
rwskinner
Active Member
Offline Offline
View Profile
« Reply #15 on: January 16, 2012, 10:40:02 PM »
First,  Thank you for all the help!
Mach allows me to jog around with my arrow keys but when my screen 11 is displayed they no longer work.  My jog buttons on the screen work fine, but the keyboard arrow keys don't.
What in the word would cause that?
Richard
ger21
Global Moderator
Online Online
View Profile WWW
« Reply #16 on: January 16, 2012, 11:07:47 PM »
You need a Jog On/Off button on each screen you want to jog on.
rwskinner
Active Member
Offline Offline
View Profile
« Reply #17 on: January 16, 2012, 11:20:51 PM »
Thanks Ger21, Your a Pro at this.
Richard
Pages: « 1 2   Go Up
Print
Jump to:
