Hello Guest it is June 12, 2026, 03:55:32 AM
Author Topic: Mach 3 setup  (Read 6268 times)
Mach 3 setup
« on: January 12, 2012, 04:08:33 PM »
Hello, I am upgrading from Mach 2 to Mach 3 and I do seem to be abel to get Mach 3 up and running right.  I have the motors turning and set the steps up and seem to have axis moving, but when I load job and try and cut, it seem that the x axis want to start job and then start to run off table.  Could anyone help me with this?  My Mach 2 ran perfect.  Any answers.  Thanks
Re: Mach 3 setup
« Reply #1 on: January 12, 2012, 05:19:14 PM »
Seems like you are missing steps. Lower the acceleration and velocity. OR make sure the cutter is located correctly for the program to be run
