Hello
Guest
it is
June 12, 2026, 05:47:16 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
SmoothStepper USB
(Moderator:
Warp9TD
Why Smoothstepper made a pause between commands ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Why Smoothstepper made a pause between commands ? (Read 10746 times)
bluewave65
6
on:
January 11, 2012, 09:20:43 AM »
Hi everybody,
i got a problem with smoothstepper and mach .....
if i send to SS these :
G1 X49.914 F10000
G1 X49.914 Y0.042
He made a pause between them .......
How can i fix it ?
Is it possible ?
Carnoustie, Scotland
Re: Why Smoothstepper made a pause between commands ?
Reply #1 on:
January 11, 2012, 10:40:06 AM »
If it just a momentary pause it would seem you are in exact stop mode (G61) Change to Constant Velocity mode (G64) and see if that helps.
bluewave65
6
Reply #2 on:
January 11, 2012, 11:36:20 AM »
That`s the problem : I`m not in exact stop mode ............
Reply #3 on:
January 11, 2012, 01:25:13 PM »
Can you attach your xml and also the code that you are using and is it between all lines of code or just specific ones? Also is it just a momentary pause or is it longer?
Print
Pages:
1
Go Up
« previous
next »
