Hello
Guest
it is
June 09, 2026, 05:02:30 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
adding a second mpg
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: adding a second mpg (Read 8380 times)
comet
338
adding a second mpg
on:
January 01, 2012, 08:06:31 AM »
Hi,I want to have 2 mpg'd on my 3 axis mill,mpg1 will switch between Y & Z axis using 186 and 187 oems, but I want mpg to be on x only I dont really want to use 281 toggle axis for that.Any Idea?
regards
Tony
Re: adding a second mpg
Reply #1 on:
January 01, 2012, 08:16:06 AM »
Use dedicated pins for the X mpg?
comet
338
Reply #2 on:
January 01, 2012, 08:18:46 AM »
not really with you there Rich? dedicated pins? Im using a pci pp card to operate the mpg set up
comet
338
Reply #3 on:
January 01, 2012, 11:19:27 AM »
how do I dedicate the pins?
Reply #4 on:
January 01, 2012, 03:32:58 PM »
I use two MPG's and in Config>Ports & Pins> Encoder/MPG's....MPG#1 & #2 are enabled, use the same port but use 4 different
pin assignments for the A & B Pin#.
Print
Pages:
1
Go Up
« previous
next »
